Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented here at
bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under scrutiny is almost guaranteed to hit its thermal limit; the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as Crysis running at a certain point also isn't reflective of real-world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary between play-throughs.
We used to use the Canyon Flight test of 3DMark 06, as this was a punishing and repeatable test. However, we've now adopted
Unigine's Heaven 3.0 benchmark, as its DirectX 11 features will stress all the parts of a modern GPU. Using our regular Unigine benchmark settings, we watch the power draw from the wall between the grass field scene and the second dragon scene - this is the toughest portion of the test for both Nvidia and AMD hardware.
        Nvidia GeForce GTX 660 2GB
        AMD Radeon HD 7850 2GB
        AMD Radeon HD 7870 2GB
        AMD Radeon HD 7750 1GB
        AMD Radeon HD 7770 1GB
        Nvidia GeForce GTX 650 1GB
        Nvidia GeForce GTX 650 Ti 1GB
        Nvidia GeForce GTX 650 Ti Boost 2GB
            98
            99
            100
            104
            104
            105
            106
            107
    System Power consumption in Watts
            144
            161
            167
            186
            196
            216
            230
            231
Thermal Performance (Idle and Gaming)
We also have GPU-Z running in the background, and leave the Unigine benchmark running for ten minutes to record a peak GPU temperature. We present the temperature as a delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
    Delta T in °C
    Delta T in °C
*as there's no stock model of the HD 7850 2GB, and we do not have a stock HD 7790 1GB model, these cards are not included in these graphs.
Read our
performance analysis.
